Thread: New machine evaluation / testing
    Oct 2014
    BAHRAIN
    We are in the process of procuring new PVC injection molding machines and we have to test the machines at the machine manufacturers side. Does anyone suggest what are the important points should consider while testing machines. Some of the scope includes
    • fill time consistency
    • shot size consistency
    • transfer time consistency
    • load sensitivity test
    • pump motor vibrations/abnormal sound
    • hydraulic leaks
    Does anyone can help with a format/template for machine evaluation form.... Thanks in advance
    507
    Re: New machine evaluation / testing
    Are these new presses?
    Looks like you've got the main ones...... RJG has a tryout/performance list, I can't remember if it has anything you don't, but it would be worth a look.
    105
    Stating the obvious, but – check and double check all safety features.
    Watch the barrel heats to see how far they fluctuate.
    Do a fill linearity study: Make shots at a range of speeds from maximum to very slow. Record actual fill time. Graph fill time versus speed setting. It should give you a dead straight line. If the line falls off at the top end, the machine is not producing the speed it claims it is.
    Oct 2014
    BAHRAIN
    Quote Originally Posted by brentb View Post
    hi Brent,
    These are new machines.
    Oct 2014
    BAHRAIN
    Hi Jay,
    Thanks for the help
    Oct 2014
    BAHRAIN
    hi Joel,
    Thanks for the help. Sure will check it ..
