Thread: Suck back to set check ring, .... is telling what?
    Wanted to poll the experts here.... we have a 500 ton machine, (sorry I don't know the screw size as yet) and if you don't have at least 10 mm of suck back (on at least two different materials I have seen) the check ring does not set, and it will not hold a cushion.... does this mean the screw/tip assy is worn out and needs to be replaced, or is this just normal/ok?
    thx! Joel
    87
    Re: Suck back to set check ring, .... is telling what?
    Have you tried a fast injection stroke at the beginning to "set" the check ring? So if your shot size is 2.3" + .25" decompression go with a fast speed to 2.3".
    524
    What kind of NRV? Does it have a castellated ring/tip?
    At least give machine make and/or model!
    Quote Originally Posted by iautry1973 View Post
    thanks, yup I've seen that too..... for this last job I had to fill slow at the beginning for cosmetic reasons.... but I also remember that press requiring more suckback (than i thought it needed) for another job too.
    thx! Joel
    Apr 2012
    Shenzhen, China
    22
    We have Ferromatik/Milacron and Milacron/Elktra machines (650T / 80mm) that we have to use 8mm to 10mm decompress to get a consistent cushion. Running PP. SAN and GPPS.
    Quote Originally Posted by tbramel View Post
    OK.thx..... our screw is also 80mm (found out later) .....sounds like we are in the ballpark. Thx!
