Thread: Injection molding with PA
    Dec 2012
    Serbia
    107
    Recently we started to work with PA 678 on injection machine, and we facing to long dosage time. Sometimes is over 1 min. Only way that i found to shorten this time is by putting negative back pressure, around -10 bars, but with this back pressure we have problem with injecting different volume. Also there is not equal dosage time in each process.
    Is it possible to shorten dosage time with a bit bigger back pressure so that we have constant injection?
    Best regards,
    Nemanja.
    Apr 2012
    Changshu, Jiangsu, China
    31
    Re: Injection molding with PA
    nemanja,
    Try performing a Tact Temperature study (see attached spreadsheet), this will find the best feed zone temperature which will give you the shortest recovery time. I have used this many times and it is a useful tool. The spreadsheet is via Andy Routsis...
    Attached Files Attached Files
