Thread: Material selection parameters in simulation if MFI is not present in material data.
    Jan 2016
    Aurangabad, India
    16
    Post Material selection parameters in simulation if MFI is not present in material data.
    Hello Everyone,
    Hope you are all doing well !!
    Which parameter should consider if material data is not having Melt flow index.
    Thanks !!
    Re: Material selection parameters in simulation if MFI is not present in material data.
    Which parameter for what?
    Jan 2016
    Aurangabad, India
    16
    Thanks for replying Sushas Sir.
    Which Rheological parameter. Apart from Melt flow index.
    Mandar
    Mandar,
    There is a type of file that is generated and imported into MoldFlow. I do not know the type of file name. However, MeltFlow is pretty useless for any analysis since it is low shear data. You need full rheological data to do any kind of simulation.
    Sorry, cant help more since I do not deal with this on a daily basis.
    Hope someone else can give some insight.
