Thread: Percent Change in MFR after molding
    Apr 2012
    Changshu, Jiangsu, China
    31
    I was wondering if there is a standard for the percent change in the MFR of a given resin after molding?
    Re: Percent Change in MFR after molding
    40% or less is what many molders look for.
    Yes, I have also heard some numbers. However, I am not sure if there can be a 'fixed' number. It would depend on a lot of factors: types of filler, % of fillers, length of the fibers of the fillers, the end use of the part, the starting MFI value - 10% of 25 is not the same as 10% of 75 and so on.
    I suggest that you actually test 'degraded' resin and come up with your own number. Another point to note is that MFI is not the true representation of molding injection speeds.
    Hope this helps.
    Mike Sepe has some excellent articles on this subject in "Plastics Technology"
    Material testing series.
    Yes, Mike Sepe is THE BEST!
