Results 1 to 8 of 8
Thread: Check ring,valve
    Sep 2013
    127
    Check ring,valve
    Hi Guys
    What kind of test do you develop in your machines to determine if the check valve has some variations or trouble and need to be reviewed or replaced ,,
    I know we have the quality control values, cushion, fill time, recovery times, etc.. but another test to determine if the check its holding the appropriate cushion
    regards
    Apr 2012
    Changshu, Jiangsu, China
    31
    Re: Check ring,valve
    Josue,
    You can do a Check Ring Repeatability test based on shot weight. Set up your process to run a decoupled II process and remove the pack and hold time and pressure (I add the time removed to the cooling time to maintain the same residence time). Be sure that all parts are short. Run 10 shots and weigh the parts and runners. Calculate the percent variation of the ten shots. Less than 3% variation should be good.
    Regards
    Tim
    Sep 2013
    127
    Thanks TBramel
    Good Advice
    regards
    Nov 2015
    Wroclaw POLAND
    Hello All,
    another way to check the ring.
    During normal production, stop the machine before machine dosing full dose.
    Wait 30 seconds and try to inject manually next dose (you have a full parts inside the cavities).
    During manually injecting you should check the stroke which you inject the material. If is only few mm then is ok, if you screw constantly going to zero position then you know you ring valve is damage.
    p.s. sorry for my language, im still learn english
    Best regards
    Yellow
    EU
    125
    and Your runner system is crying!
    I don´t recommend this. Maybe in rare ocasions its ok.
    j
    Nov 2015
    Wroclaw POLAND
    Jendalf,
    such a thing is done very rarely so in my opinion is ok.
    Best regards
    Yellow®
    Aug 2016
    19
    if you can see the screw turn when it injects that is a good sign that plastic is flowing backwards across flights towards throat, sometimes a bridged throat is a good sign of check ring trouble to.
    Aug 2016
    19
    You can try more screw suck back to seat the check ring
