13th July 2016, 01:44 PM
Blown heat exchanger
I lost a heat exchanger. I now have water in my oil and oil in my water. Any suggestions on how to get oil out of tower system or is this something that will eventually clear up. We purge our holding tank once a week when we shut down.
13th July 2016, 02:48 PM
Re: Blown heat exchanger
Water in oil is worse than oil in water! " Flush" tower system well (fill-run a bit- e. If you don't havempty and repeat) then install a "water eater" filter element. If you don't have Filtroil type auxiliary units get filter carts, then you can install a central water system filter.
Remember the important thing is to take the water out of the oil!
