Thread: Optimization of Maximum injection pressure.
    Jan 2016
    Aurangabad, India
    16
    Hi All,
    Can someone explain how to optimize Maximum injection pressure .
    Material: POM
    Pressure limit : 120Mpa.
    Thanx & Regards,
    Mandar
    Re: Optimization of Maximum injection pressure.
    Hi Mandar, the pressures that the manufacturer give you is a useless number.
    On a closed loop machine, you need to set the pressures about 200 psi more v than the peak pressure. Send me an email and I will send you the 6 Step Study procedure. (Or you already may have it)
