Thread: Screw speed units
    Nov 2015
    Question Screw speed units
    When specifying the recovery/dosing rotational screw speeds some injection molding machines as well as processing datasheets use the circumferential speed (mm/s, m/min, in/s..) whereas others use rotational speed (rpm). While circumferential speed makes more sense, rpm seems to be a popular specification unit for this parameter. Why is that? What screw diameter should I assume from the material process datasheets to make the correction when setting up my specific machine?
    What is the most popular unit being used in mother machines?
    Mar 2014
    Minnesotan living in Wisconsin
    28
    Re: Screw speed units
    When I look at resin process information I assume a 25 mm screw and a 13:1 intensification ratio.
