24th August 2015, 04:55 PM
Metal Separator
Hi:
I want to ask you if you guys know or use a metal separator on top of the hopper, i would like to install one I one of aour machines, Currently we have one, but i would like to test a diferent brand or model, this unit should be capable to separate ferrous or non ferrous metal
if you can recomend some model or supplier will be appreciate
Best regards
24th August 2015, 10:06 PM
Re: Metal Separator
Hi Josue,
I am not sure of a brand but I would suggest that you ask for a 30 day trial. Then, take about 10 lbs of material and on purpose mix ferrous and non ferrous materials to it. Also, weigh the metals before you mix them. Then use the separator, separate out the metals and weigh the metals again. If you get the same amounts, then the brand is good.
I suggest you do this at least 5 -6 times with 2 or 3 brands.
25th August 2015, 01:12 AM
Re: Metal Separator
Best in the world, S+S but NOT cheap!! But you get what you pay for. Try one and you won't use anything else.
25th August 2015, 02:16 PM
Re: Metal Separator
Ok, i will investigate, thanks
25th August 2015, 06:48 PM
Re: Metal Separator
Greetings;
There are two types also analog and digital, digital being the better and more expensive. Also you need to make sure it's rated for the material thru put.
Scott
25th August 2015, 09:20 PM
Re: Metal Separator
I already quote the S+S,,, electronic detector, capable to detect from 0.3mm,,, the cost its 7K usd
we will compare vs other units
thanks
26th August 2015, 02:53 PM
#7
Re: Metal Separator
Greetings;
Like Suhas said, get a trial unit for a period of time to try it out, I would try and get a few units from different companies and try them at the same time.
Scott
26th August 2015, 07:12 PM
#8
Re: Metal Separator
I'm telling you I haven't seen another work as well as the S+S unit for ALL metals; period!!
