Thread: shrinkage factor for PBT
    Sep 2013
    127
    Hi
    I Try to get the shrinkage factor for PBT DURANEx 200K,, unfortunatly I can get it,,, I appreciate if some share this information ,, I can see many data sheet on line , but this item its not shows,,,
    Best regards every body
    Re: shrinkage factor for PBT
    Hi Josue,
    The best thing is to go after the company supplying the resin. They have to give that you. (If not you need to find a new supplier - )
    Also try on IDES.
    Sep 2013
    127
    Thanks you
    I try IDES , but doesnt show the Shrinkage, any way I already receive the answer from resin supplier, they also dont haveit like the std "technical data sheet",, so they anwer by email only as follow
    3mm of tickness
    0.022 - 0.019 in/in = 2.2% - 1.9% (from 50 to 70 MPa)
    But if your product has thicker thickness, I would like to recommend as below.
    0.022 - 0.017 in/in = 2.2% - 1.7% (from 50 to 70 MPa)
    regards
    Good, depending on your part size be conservative on the numbers.
