Thread: determine the material
    Jan 2014
    10
    HI EVERY ONE
    I want determine the material to be use for this part and which ( MFI melt flow index ),
    Such as the part must be flexible may not breakable
    pls find In annex the part photos
    thank you in advance for your answer
    Re: determine the material
    Hello Simo1,
    looks like the part picture did not get attached. However, the MFI has nothing to do with the plastic mechanical properties. Yes, there is a correlation but not definable. You will also need to consider other requirements such as misc mechanical properties, chemical, aging, etc. I suggest you make a full list and run it by a local material supplier. You can post it here also.
    Hope this helps.
