28th March 2014, 12:26 PM
determine the material
HI EVERY ONE
I want determine the material to be use for this part and which ( MFI melt flow index ),
Such as the part must be flexible may not breakable
pls find In annex the part photos
thank you in advance for your answer
29th March 2014, 04:13 PM
Re: determine the material
Hello Simo1,
looks like the part picture did not get attached. However, the MFI has nothing to do with the plastic mechanical properties. Yes, there is a correlation but not definable. You will also need to consider other requirements such as misc mechanical properties, chemical, aging, etc. I suggest you make a full list and run it by a local material supplier. You can post it here also.
Hope this helps.
