Thread: i am using recycled materials, how to eliminate dirt clogged at hot runner tip?
    we use recycled material for production. We often have to clean dirt clogged at hot runner tips. I have been trying some hot
    runner systems but still have this problem. Any ideas to eliminate this routines?
    159
    Re: i am using recycled materials, how to eliminate dirt clogged at hot runner tip?
    Are U using recyclate as regrind or regranulate?
    I suppose, that it will be regrind material. You have to have good metal separator befor screw, which will remove all metal particles. For other dirty you can have a mesh filter insert under nozzle tip (on the barrell). This can be cleaned after nozzle disassembly.
    The situation with regranulate is little bit comfortable, because this material is prepared with cleaning procedure.
    Santa Rosa, CA
    95
    When designing hot runner systems its important to be able to take the bolts out of the cavity plate, close the mold, strap the cavity plate to the core plate, and open the mold and pull the cavity plate to expose the hot runner tips. We call it "de-capping" the tips. Heat the tips up and remove the caps. I would then use an ejector pin and check the tip flutes to make sure all 2 or 3 are open and not plugged. One company I worked for made HVAC automotive vent doors out of Minlon (mineral filled nylon). We had to "decap" quite often when the mineral would build up on the outside of the tips. Purge through the mold (put the back pressure at max and extrude) and you can usually see the restriction.
    Buy an INCOE SPM nozzle/melt filter. They are great! Do purchase filter with filter media smaller (finer) than gate drop size.
    Hi Herman,
    is important to control the operation in the grainders as principal solution, but you can use a tram filter nozzle
    Regards
