7th December 2012, 01:59 PM
Plastisizer Trap
Does anyone know how cold the water supplying a trap needs to be? Also, how much air flow is needed to effectively draw out some of the plastisizer of a Cellulose Acetate. Right now the plastisizer is leaking out of the bottom of the dryer and there is none in the trap
10th December 2012, 04:09 PM
Re: Plastisizer Trap
I've just used straight chiller water in a trap; and all the traps I've ever used were home made!? 35 gallon steel drum with inlet tube at the bottom with a end to cause the air to swirl around the inside back towards the top of the drum. Then a long coil of copper tube inside for the water to flow through.
18th December 2012, 05:28 PM
How cold would you be running that chiller?
18th December 2012, 10:06 PM
I think our plant water was like 65*F or so. We couldn't run any colder due to mold sweat.
