22nd August 2012, 05:24 AM
Worst part molded
Don't care if its mold, mold design, tolerances, material, or if its just the customer. ( You know the one that wants the part in plastic with properties of steel, or tell you set the mach on low-med-high :^| lol how about broil.)
23rd August 2012, 05:40 AM
Re: Worst part molded
A customer got me a part being molded elsewhere, got me the resin and asked me to mold it the same as the other guy. Worked on it about 18 hours a day for 4 days changing process, machine, screw and barrel, etc, etc to find out that he had shipped us the wrong material !!!! It was very frustrating!
25th August 2012, 03:16 AM
An acetal job that stuck to the mold like crazy, and no one had robots back then. So you had to have an operator remove by hand. What a dog!!
27th September 2012, 04:01 PM
I've been running a PVC job for about 5 years now. Complete pain in the ass. If I could choose not to run PVC ever again, I would.
16th January 2013, 04:35 AM
worst tool i have ever seen was a 39t stacker mould, the hot runner setup was so complicated it looked like a 6yr old had designed it. it never worked, couldnt make a good part to save its life, in the end we had 2 tools built to replace it. Even now it makes me angry thinking about it. A close second was a set of tools running 30% glass filled abs/pc, the material went off in the hot runner if the machine stopped for 1 minute. we had to start up and shut down the tools using natural abs to get the tools to run. there are many others, but thats another story.
16th January 2013, 11:23 PM
Not sure this is the 'worst' but once I was asked to come in a do a new mold validation. Went there to find out the mold had NO water lines. It was sort of a 3/4 inch long tube closed on one end - eight cavity cold runner. Now what do I do??? I was told the old mold needed to be shut down every 4-5 hours. Robust processing? - out of the window, into a deep well I guess.
