Thread: Nautilus 2010
    Jun 2012
    Rhode Island
    4
    Nautilus 2010
    Gentlemen, I am trying to familarize myself with the DOE aspect of Nautilus and was wondering what your thoughts were on a coulpe of things.
    1.On the Define Variables page , what's being looked for in the Precision box? I'm not sure if I should put the # of decimal places desired or the increments of change from one experiment to another.
    2. On the Qualitative box , it's asking for Least desirable and Most desirable. Is this for a rating (1-10 where 1 is least and 10 is most) or something else?
    We are a TPE manufacturer and I want to be able to use the program with our customers, so any suggestions you can give would be greatly appreciated.
    Re: Nautilus 2010
    Precision - This is the minimum amount of change in the parameter that you think will make a change in the quality of the part. For example, what is the minimum change in the amount of holding pressure you think will make a difference in the part? Will changing 1 psi make a change? In theory yes, but in practicality at least a 50 psi change is required to see a noticeable difference. So the precision value is 50. For cooling time I use 1 second, mold and melt temps I use 5 deg F. This number will also show up as increment steps after you do the analysis and look at the prediction equation tabs - both numeric and visual.
    Qualitative - What is the most desirable? = Zero Splay - Least desirable = 5 (or any other number you prefer).
    Let me know if this helps.
