23rd July 2012, 06:02 PM
Annealing for automotive parts injected with PBT and POM
Actually we have a annealing process of 2 hours of duration i want to know if exist some procedure to dterminate the time for these proceseces kind.
I will appreciatte the help
regards.
23rd July 2012, 06:28 PM
Re: Annealing for automotive parts injected with PBT and POM
Hi Arturo,
Since the final dimension will also depend on your molding process (mold temps, melt temps, pressures, etc) you will have to conduct experiments to see what is the best combination of temperature and time. Plot a graph of Dimension vs Time at three different temps and see how the graph looks. I suggest that you take the higher end of the suggested mold temp as the starting point and then step down.
Hope this helps. I am sure you will have some other replies also.
23rd July 2012, 10:19 PM
some body know what type of testing is apropiate to verify the annealing level?
