Thread: drying parameters for technomelt PA 638
    Oct 2020
    19
    hello All,
    Please I need your help to define drying parameters for Technomelt pa 638 because I face a bubbles issue on the material.
    N.B :
    Current parameters 50C/6 hours.
    Low-pressure injection.
    Best Regards
    Attached Thumbnails Attached Thumbnails ce6ca177-a478-4141-a6b2-9e15e2fbd2af.jpg
    Re: drying parameters for technomelt PA 638
    I looked the resin up and it says NOTHING about drying it!? It tells you to place it in an airtight container ASAP when opening the packaging.
    I did notice that this resin carries a FR rating. Perhaps you have the barrel set too hot or the residence time is too long?
    Oct 2020
    19
    thank you for your feedback, i will check this.
    123
    Rick is probably right, this seems like process temperature setup in the IM - not drying.
    Dec 2012
    Serbia
    104
    On Technomelt 678 im using 30C for 4h, and that solved this problem for me. On datasheet is saying that drying is not required but without, surface of parts are like moon surface because of bubbles.
    Oct 2020
    19
    Nemanja Thank you for your feedback, I used the exact parameters you mentioned, then the problem was solved.
    Salutations.
