Thread: Injection Profile Engel Emotion 310
    Mar 2019
    Nebraska
    33
    We are setting up to do some process development on a tool. We have not been to able to figure out why our injection pressure is peaking around the same position during injection regardless of injection speed. Injection Pressure Limit is set to machine max (29000)
    6.000 in3/sec [html]https://snipboard.io/9doeOa.jpg[/URL]
    3.000 in3/sec [html]https://snipboard.io/Tjc02w.jpg[/html]
    2.000 in3/sec [html]https://snipboard.io/2efSbm.jpg[/html]
    Engel e-motion 310 (2016)
    ABS
    Melt Temp: 440
    Hot Runner: 460
    Melt Delivery: Hot Tip
    We are wondering if it could be a setting on the injection page that might be causing issues or possibly if the hot tips need to be "warmer" so we don't generate as much pressure trying to inject. No idea to be honest but we will be continuing to adjust settings and send any updates.
    [html]https://snipboard.io/M4oVjU.jpg[/html]
    Any feedback would be great!
    Dec 2012
    Serbia
    107
    Re: Injection Profile Engel Emotion 310
    Did you do fill study?
    How much part is filled in point when preassure goes up?
    What are yours speed profies? Do you have one or more injection speeds?
    Regards.
    Have you looked at the Microplast graph and seen exactly where the peak pressure ocurrs? You could be hitting the end of the cavity or the pressure peaks there due to the melt temperature being too low which causes the press to raise the pressure to maintain the the injection speed. What is the peak pressure? Is increased injection pressure On? If so, the press dumps off the other side of the injection cylinder instead of using it in a regerative mode which lowers max injection rate. How much of the press shot size are you using? Is the resin a UV or FR grade resin?
    EU
    125
    in what units is the temperature?
    It seems way to high for ABS.
    J
