14th June 2021, 06:50 PM
Re: Molding Pellethane TPU Coatings used
I have used Bales Nibore coating on molds producing TPU parts with great results.
I used to have the mold builder achieve diamond 15 polish and then vapor hone finish prior to adding this coating.
It sounds like this "spark finish" that you are referring to has helped you already though.
22nd June 2021, 01:13 PM
Hi thanks for the recommendation for the Nibore coating. We actually used this on a different mould and different material and had great success. Had forgotten about it. Will look in coating these pins for the TPU material.
23rd June 2021, 12:32 PM
Please remember to give an update after the implementation. Thanks
13th July 2021, 01:47 PM
Unfortunately the Nibore coating was no addition to stripping the TPU Pellethane from the core pins.. Still have an issue of the part deforming when pin is been stripped out of the part. Back to the drawing board again.
