Results 1 to 8 of 8
Thread: KM Not achieving clamp pressure.
    Mar 2021
    9
    Hi, we have a KM 200-1000 C1.
    No matter what the clamp pressure is set at, the actual value is 8-9% below what it is set at.
    The brings up the clamp pressure not achieved alarm.
    Is this the pressure sensor needing calibrating? If so, is it possible to do it or do we need KM to do it?
    Thanks.
    Re: KM Not achieving clamp pressure.
    Yes, you will need to calibrate it. However, if you have not have much experience with it, it is well worth to get the KM Tech to do it.
    Mar 2021
    9
    Thanks, are there instructions available anywhere on how to do it?
    158
    REMARK:
    the calibration is necessary. Please contact KM service. it is a best way...
    Before, please check the clamping force drop after 10 minutes. If it is too much more than 12% of clamping force achieved directly after loading, can be clamping unit resealed.
    The calibration of machine is not only calibration of pressure sensor, but also calibration of hydraulic pump output p/v and p/v control card. KM is using also Bosch rexroth control card for pumps.....
    First of all, please try to clean el. connector on pressure sensor and wire...
    Mar 2021
    9
    Someone has been out and all is good now thanks.
    EU
    125
    Leprechaunts?
    158
    yea Leprechaunt ....
    Sep 2014
    albuquerque
    66
    Greetings;
    My question would be when was the last time the column seals and intensifiers rebuilt? Not a fun job but some KM's need to have them done almost yearly.
