20th November 2020, 03:16 PM
Re: Problem during TPE processing
hi, which TPE-SEBS material are you useing? Brand name please :-)
20th November 2020, 03:22 PM
Brand name and type: LIFOFLEX XGEA17 UV 252404-5 NATUR
20th November 2020, 03:48 PM
HI, I do no know this material exactly, but generally.... The processing temp 200 °C looks good, if it is also on hot runers. The issue can be overheating of TPE, which can bring a odour and vaporisation .... and some of this dirty can stick on the barrel, hot runner etc.
Please check the material temperature directly after purging. My opinion 220°C max. Try to reduce backpressure and screw temp profile also down.
Also the issue can be hot runner controler which can overheat the material during start up. Also all sharp edges in material flow way are dangerous.
The residence time is pointing on temp. sensitive material. :-)
23rd November 2020, 08:32 AM
Do you use virgin material? Is it possible that you can mix materials? Is drying necessary and if, how stable process is.
I didnt work with this material, but i had similar problems with TPE materials.
Also maybie is good idea to clean hot-runner when is "open" (remove valve pins to get biggest possible diameter on hot-runner exit).
I had situation with building up burnt material on walls of hot-runner and after some time pieces of that material end up in gate.
25th November 2020, 08:11 AM
Thanks for the replies!
I was busy on this week. I will check the temperature of the melt after purging.
@nemanja
Yes, we use virgin material. We store the material separated, I think there is no possibility to mix it with other TPE material. Drying is not necessary for this material (according to the datasheet). The process is stable. As I wrote, after few weeks of production the injection pressure increases (for example from 410 bar to 455 bar).
The fill time is stable 0,78 s, but when the pressure increases the fill time also increases to 0,81 s
I'm sure the TPE contamination decreases the diameter in the hot-runner, this issue cause higher pressure and longer fill time.
So the promblem is a little bit complex. It's hard to investigate the flow in the hot-runner manifolds or in the hot runner tips.
In the past the machine maintenance checked the screw and the barrel. There was no burned TPE in the screw threads.
@Pilot
As You mentioned, the material can burn at the start-up of the machine. We use purging compound after the machine or the production stops. So there is no TPE in the hot-runner, the purging compound can withstand higher temperature. After the hot-runner reaches the set temperature, the production starts. There is no longer stillstand time between heat-up and start of production. The cooling of the hot-runner turns on after the heating turns on (machine setting). At start-up, the PP zones starts to heat-up, and after these zones reaches 80% of set heat the TPE zones starts to heat (Pre-heating of TPE zones). Maybe the heating-up is too fast for the TPE zones. I will investigate this.
25th November 2020, 01:35 PM
As Pilot mentioned above, sharp edges in the melt flow path can cause burning. Check that when the gates are open, the valve pins are retracted out of the flow channel. If not, material flowing past the end of the pins may see excess shear and burn on to the pins. If that is what is happening, see if you can use shorter pins with longer travel.
26th November 2020, 05:20 PM
please check also nozzle tip and seat diameter if are the same. Please check hole quality if the edges are not "mushroomed" :-) without sharp.
