29th July 2020, 02:08 PM
Re: Rare cosmetic defect
Horeki,
It looks somewhat like a voids are forming in the base of that cup and the layers of plastic are separating from each other. You said it only occurs after running non-stop for 100 hours. Is this a hard number or could it be happening more often than that but its hard to catch? Is it every cavity or just some of the cavities (assuming a multi cavity tool). I would be looking at the tool temperature difference between the core and cavity when you start seeing the defect to see if there is a possibility that one side of the tool is hotter than the other. I would also measure the temperatures of the core and cavity lets say after the press is up and running for an hour or two and then again when the defect occurs to see if the tool temperature on one side or both sides are changing.
Sticking with water, I would make sure consistently have turbulent flow through the channels and that flow isn't being restricted anywhere.
Hopefully this helps.
-Robert
30th July 2020, 03:06 AM
To me it looks like either poor color dispersion or unmelted pellets. I would watch the screw recovery pressure at start and then check it every half hour. I think you’ll find it low at the start and then increasing as it runs proving throughput is out pacing temperature settings on the barrel. Then just increase heats slightly across the board until the screw drive pressure drops back down to where it started.
31st July 2020, 08:54 PM
Unmelted resin or contaminated with some higher melt resin maybe?
