Thread: feeding and injection
    Jul 2020
    hello i am newbye here, i am operator on injection molding machine U180T, few days ago compiuter died and we bought new part so everything restarted on computer so i set up everything , so can not fix feeding it needs 13 secund to feed plastic i think it is delayed can not decrease the time of feeding plastic i have increased pres bar pressuare and flux% (speed) but nothing changed, before computer died it needed 1 sec to take plastic how can i fix it tried almost everything , i think it is delayed from somewhere help me . ps sorry from my bad english
    587
    Re: feeding and injection
    Do you see that the screw is actually turning for all of the 13 seconds?
    Jul 2020
    Quote Originally Posted by Suhas View Post
    yes, there are also two machines and they need 1-2 sec for feeding
    Jul 2014
    Lincoln, NE
    19
    pshavela,
    Can you either provide screenshots of the injection and recovery page (if separate) or just the values to the settings and outputs below.
    Shot Size
    Transfer position
    Cushion
    Screw RPMs (if in % please provide max RPM rating for machine)
    Back Pressure
    Screw recovery delay
    If the screw is rotating the entire 13 seconds then you are either having issues feeding the material, or the shot size is too large to recover faster than that. Any type of delay would stall the screw from rotating until that delay was over, meaning if it was recovering in 1 second before, you could see the screw just sitting there for 12 seconds and then rotate for 1 total second. If you provide the information or screenshots for the above I can try to help further.
    Jul 2020
    is it possible to send you screenshots and videos here?
    Jul 2020
    shot size is 70 mm and it needs 12-13 sec, i have decreased to 30 mm but it needs 5-6 sec, than i went to delay set eveyhting is 00 nothing is delayed, incrasing press bar and flux% and it had no effect , feeding is slowed delayed but i van not find how to solve it
    Jul 2014
    Lincoln, NE
    19
    You should be able to add images and videos using the buttons above the message box to your messages. Click image for larger version.
Name:	injection molding forum.jpg
ID:	471 See attached image.
