Thread: Ferromatic machines lubrication failure
    We have a problem with automatic lubrication resetting after attaining 1000 shot, which gives a lubrication failure alarm. How do I resolve it.
    EU
    105
    Re: Ferromatic machines lubrication failure
    Can you setup the automatic lubrication? there will be setting which you can solve your problem.
    If its not working properly than contact technical support at F-M, They will know for sure what to do.
    J.
    We have been resetting but after 5 continuous automatic reset it again fails automatically unless you reset manually. We have opened the lubrication pump in case of air trap, checked transfer signal connection ok but no good result achieved
    Feb 2020
    6
    assuming it is a MTS , the lube pressure switch is on the lube manifold on the movable platten.
    If the machine is has fresh lube on the tiebars it is usually air in the lube system. if there isn't new lube, it is likely that the lube line from the rear manifold to the front one is clogged.
