Results 1 to 17 of 17
Thread: 20% GF PP Warp
    Jan 2020
    14
    Re: 20% GF PP Warp
    Just out of curiosity have you tried cure time ?? If so was it a big increase small ??also with pack pressures have you tried more or less?? And how are you filling it d-2 or d-3 what part percentage does each stage transfer at??
    Nov 2012
    159
    Re: 20% GF PP Warp
    I need a more photos of part with gating. the warpage is due to glass orientation, which (maybe) can be change due to injection cascade stategy …. and materiál press in the area (maybe some area must be without holding pressure (close gate on HP). .. and tool temperature profile...
    Re: 20% GF PP Warp
ID:	449Click image for larger version.
Name:	MCA Bin Top.jpg
ID:	450Click image for larger version.
Name:	MCA Bin Side.jpg
    This is the bin I had issues with. A change to 20% TF PP solved the issue.
    I have adjusted the pack/Hold times and pressures. Cure time... I shaved 10.0s off and added 60.0s. Neither changed the warp whatsoever.
    Nothing I changed made this warp any better or worse.
    We are running a decoupled 2 setup.
    I will post pictures of the seatback shortly.
    Re: 20% GF PP Warp
    First, you are absolutely right on this: 'My conclusion is that the orientation of the fibers is causing the warp.' Fibers orient whereas talc does not since it is a powder.
    You may have tried this but the other thing I can think of is to try differential mold temps. The side towards which it is warping should have a lower temp.
    Re: 20% GF PP Warp
    I tried up to 45° difference and still nothing. I was not comfortable (nor was I at this point either) running any higher for production. This was just an effort to see if the warp could be changed any.
    Re: 20% GF PP Warp
    Possible to create a cooling fixture so that the parts cannot warp while cooling?
    Re: 20% GF PP Warp
    The parts are already warped as soon as the robot drops it in the cage.
