13th February 2020, 07:27 PM
Re: Injection Molding Process Sheets
We use machine-specific templates that we use to make job-specific set up sheets. Both the templates and set-up sheets are controlled documents, stored electronically in the doc control system. We print out a paper copy with each lot traveler, which the set-up tech fills out with actuals by hand. In practice, the set ups are stored on and loaded from the press, but the techs are required to confirm that the settings conform to the set up sheet.
