Results 1 to 9 of 9
Thread: Processing Troubleshooting
    Jul 2012
    Belle Vernon, PA
    129
    Good Evening,
    I'm injection molding some parts from homopolymer Polypro. We're getting these white marks on the same spot on every part. I'm trying to troubleshoot what it is and how to fix it. It's a white mark that is causing shortness in that spot. I was thinking it's some type of "pre-burn," as when I bump the injection speed up, it does burn there. I can't seem to get this to go away, even with treating it like a burn (lowering injection speed and pressure, lowering temp, lowering residence time). Any suggestions would be appreciated.
ID:	428Click image for larger version.
    Sep 2013
    117
    Re: Processing Troubleshooting
    cant see pictures, cant se gate positions, set the full picture including runner,
    EU
    105
    its trapped air. It means You have to provide proper airventing, but first start with parameters.
    Check the clamping tonnage first and set it safe low as possible. Than play with temperatures and injection speed. Try to moove it a bit to the corner. Part have probably only one injection point so it will not work at all. Than ask toolmaker to make a proper air venting there.
    First by slightly roughing the split line surface of the tool at the place of white spot only (roughing pater 600-800grain) - DONīT TOUCH THE PARTING LINE NEVER!
    Than by groove the the airventing channel close to the point of burn mark - The skilled tollmaker should know how to do it.
    J
    Jul 2012
    Belle Vernon, PA
    129
    Quote Originally Posted by Josue View Post
    I can't post anything more than I already have, sorry.
    Quote Originally Posted by Jendalf View Post
    J
    That's what I was thinking too, but we have run this tool over the last year and this has been the first time we've had this issue. This is also the first time we've run this color, maybe that's causing an issue as well. I'm going to play with it this week and see if I can get any differences out of the other colors we run.
    Mar 2017
    South Africa
    11
    Use a small piece of masking tape on the vent is a quick way to check if venting is your issue.
    EU
    105
    Quote Originally Posted by Crabstix View Post
    Thats good point to check how the contact surfce looks like.
    When You do the soft airventing than after some months this airventing is completly off or different how the tool halves are touching each other.
    Check that with the paper or spotting colour also.
    Share pictures if you can,
    thx
    J
    Jul 2012
    Belle Vernon, PA
    129
    I lowered the tonnage and it seemed to go away. Thanks!
    Jan 2020
    14
    Color changes viscosity and depending on the colorant could be leaving residue in any vents or along vent pins. Check to see what your viscosity shift is from the old to the new you may be running the same process but filling faster or in a different pattern causing trapped air
    Jul 2014
    Lincoln, NE
    19
    I assume that your tooling is on a PM schedule. It's possible that previously it ran at a lower tonnage as you stated that seemed to fix the issue. But documenting the correct tonnage and putting the tool on a PM schedule that include cleaning vents and vent dumps will go a long way in preventing these issues from recurring.
