31st October 2019, 02:41 PM
Re: Liquid color issue
You may not be able to get good mixing from the GP screw. If you read the Celcon processing guide (which I highly recommend you do), what you ideally need is a barrier screw with a high (3 – 3.5) compression ratio and a fairly short (6-7 flight) transition section. The question then is whether the volume/margin on the project will justify the additional cost.
