Thread: Autojector HS-30 not turning screw fast enough
    Oct 2019
    I have a Autojector HS-30 machine which does not turn the screw fast enough. The hydraulic motor turns the screw fast without material being fed but once material (Flexible PVC) is fed, the speed decreases to about 40rpm. My thinking is that either my hydraulic pump is not getting enough volume to the motor or my screw is very dull. (I'm leaning to the first.) Any ideas would be appreciated.
    584
    Re: Autojector HS-30 not turning screw fast enough
    I also think it is the first. Is there is torque setting that you can play with?
    Oct 2019
    Thank you for your response. The only control of the hydraulic motor is a needle valve. (Besides the on/off solenoid valve)
    Oct 2018
    22
    Sounds like a lack of pressure or a bad screw motor. If there wasn't enough volume, it would never rotate fast.
    Under a load, there's insufficient pressure/torque to maintain the speed. My 2 cents.
    665
    Has it ever ran correctly? Maybe your heats are too cold or not as high as they’re showing on screen.
