Thread: Yushin Robots in injetion process
    Sep 2019
    Hi everyone,
    do someone use yushin robots in your company?
    I want to change robot program on my stationary computer and I looking for software to do this.
    Could someone help me?
    Re: Yushin Robots in injetion process
    You need to purchase from Yushin. Be mindful because there are settings required for the older or newer controllers. It makes it quite easy but they are a handful at times since you must use Flex to make the motion sequence in and then at times tell the controller that certain motion and position programs are always ran together.
    172
    We use Yushin robots. Some of them you can program on the pendant however I would avoid doing that as it seems to crash them most of the time. Rick is right, contact Yushin. They will send you the software and a USB key that you need to run the program. Do not lose the key. They will give you another key if you lose it but it will cost you another $700. The software will not open without the key in your computer.
