Thread: High Oil temperatuer reading on Injection molding BOY
    May 2019
    We have a BOY injection molding machine. Yesterday I noticed a high temperature reading on oil about ~80 degree Celsius which I thought was a false reading because we shut down the machine two days ago and nothing should be hot. I check this morning the problem still persist. Do any one have any idea? is the thermosensor broken? Thank you very much for all the help and information you can provide! (I attach the screen shot of the machine window)
    May 2019
    Re: High Oil temperatuer reading on Injection molding BOY
    Quote Originally Posted by ctrllh View Post
    Hi This PRM-Taiwan, we may not give you the right answer to your quiz, but you might wanna have a look for our best hot runner system supplier, Arico.
    They are the expertise on temperature control for plastic machinery. http://bit.ly/2YN2eWg
    621
    If the pump was left running or the start up clock turned on the pump with the cooling water off, The it may be hot. Can you reach tank and put a hand on it to see if it’s really hot? It may be a bad sensor but that’s rare for the oil temperature unit.
    Aug 2016
    14
    does the pump shut off on over limit of oil temp?
