15th February 2019, 03:26 PM
Support for Moving side of Mold
Does anyone have any ideas for supporting the moving side of a mold? I have found on some of our larger molds that the mold can "sag" over time, this causes extra wear on the sidelocks and creates mismatch on the parts. We've added additional clamps, but I am looking for something would also aid in the support for the half of the mold.
I've seen the Smartline system, just seeing if anyone knows of other systems.
15th February 2019, 06:09 PM
Re: Support for Moving side of Mold
Could use some tapered mold interlocks to help with alignment. And just remove the slidelocks altogether
Closer you place the interlock to your parts, the less delta of mismatch you will see in parts
As for sagging to begin, aside from using larger bolts, rails, leader pins, etc I don't know of any way to prevent sag as it's in the construction of the mold itself
18th February 2019, 07:27 PM
I have seen devices affixed to side of tools using the tie bar as a support.
Common on with stack molds.
Looks like bronze material
19th February 2019, 02:06 PM
Easy fix would be use a locating ring on the moving side. If the ring can’t come out of the platten then it can’t slide down. BTW do you only start clamping in molds under tonnage ? If not the tonnage can cause them to move slightly.
19th February 2019, 05:54 PM
ok, what is "larger tool"? 100kg, 1t, 10t, 40t ????
