Thread: Defects
    Jul 2017
    6
    Defects
    Circle around the intake duct. Hot runner system. Material polypropyleneClick image for larger version.
    663
    Re: Defects
    Adjust heat at tip of valve gate and see if slowing the injection rate helps.
    Re: Defects
    In addition to Ricks comments, it appears that you may be trying to over pack the mould and "BALLOONING" is visible at the surface around the gate. The stress marks from the ejector pins would suggest this.
    Re: Defects
    What was the conclusion to this?
    Jun 2017
    Ningbo zhejiang Province China PR
    10
    Re: Defects
    What is at bottom, and bigger ejector the same size as the circle? Actually, I am thinking of ejector rebounding after holding pressure removed.
    120
    Re: Defects
    It looks, that the part is overpacked too much...… but this will not solve the sprue issue :-)
    Re: Defects
    This part is way too over packed to even worry about the blush at the gate. Is that defect on a short shot? Try reducing initial fill speed, adding extruder delay or reducing recovery (screw speed/BP). But first... get rid of the pin push.
