Thread: How Can I Prevent Molding Stress on Polycarb
    Jan 2018
    Greeting fellow professionals. I was wondering if you could share some ideas on some process techniques that can be used to effectively reduce molded in stress on PC parts. How can one effectively ameliorate molded in stress that could take away from PC's impact resistance?
    Thank You All
    144
    Re: How Can I Prevent Molding Stress on Polycarb
    Make the gates bigger
    Make the gates even bigger yet
    Slow the injection speed
    Anneal the parts after molding
    Round off any sharp corners in the mold cavity
    Raise the mold temperature
    Jan 2018
    Thank you for the suggestions, Jaydub
    607
    Proper mold and melt temperatures will help but you may have to profile the hold pressure portion to reduce molded in stress. Running the correct resin with additives and melt flow will make life easier. The correct size screw size utilizing an appropriate amount of shot capacity will help. A proper compression ratio helps too. Lastly don’t run resins with UV or FR additives if possible. They can bloom causing cosmetic issues and degrade with high temperatures or residence times.
