Thread: krauss alarm help
    Aug 2018
    8
    krauss alarm help
    we are getting a183: connection ipc/sr interrupted, we have tried taken mother board of in electric cabinet and spraying with contact cleaner apparently this worked before. it seems to work for a few days but then come back? has anyone had this? know how to fix this?
    Jun 2018
    Slovenia, EU
    10
    Re: krauss alarm help
    hello!
    Have you check connections on ejector/core pulling connector? If you use ejector switch with controling it on the machine and create short cut, it gives you alarm and the screen becomes untouchable. You must repair short cut and change fuse, it is usaly 2A. i will send you photos.
    Jun 2018
    Slovenia, EU
    10
    here, check cables in connector or outside of him, and check these fuses- shold be 2 or 4 A!Click image for larger version.
ID:	281Click image for larger version.
    Aug 2018
    8
    thanks for this, will definitely try if it goes again.
    Mar 2019
    Did u manage to solve this problem? I am getting the same problem but all fusses are okay
