Thread: Fiber orientation.
    Jan 2016
    Aurangabad, India
    16
    Post Fiber orientation.
    Dear All,
    Hope you all are doing well !!
    Actually, I have a doubt regarding Fiber orientation. I am using PBT GF30% material.
    Apart from changing Gate location is there any other way to change the fiber orientation?
    Please do needful !!
    Thanks and regards,
    Mandar.
    Last edited by Mandar; 29th June 2018 at 01:59 PM. Reason: Forget to mention Plastic material
    Michigan
    71
    Re: Fiber orientation.
    Fiber orientation can be affected by shear which is going to be controlled by injection speed and part thickness. I will assume you cant change part thickness either so to get more orientation you will need to fill faster, to get less orientation you will fill slower.
    Husky
    Jun 2018
    Slovenia, EU
    9
    Only speed can save you. Or try with gb material if it is possible. I had a problem because the part was visible and on my luck customer was satisfyed with gb material. Or try with some mineral fibres...
    607
    Mold temperature can influence this as well. Hotter mold will slow the resin skinning up allowing the fiber orientation to change somewhat.
    BR,
