Thread: Heater Band Overheating HELP!
    Jun 2018
    Have the same issue with two of my Sumitomos, popped a fuse on a heater, replaced the fuse, now the heaters have no limit. They just blow right past the set temp and keep going. Thermocouple seems perfectly fine, what could it be?
    Jun 2018
    Re: Heater Band Overheating HELP!
    A: Solid State Relay
    Jun 2018
    10
    I had the same issue just a few days ago, and I tested the resistance in my thermocouple, seemed fine, but I replaced it anyways, problem solved.
    Jun 2018
    it could be the SSR is broken or its signal from controller always on try to swap SSR with anther heater
    Jun 2018
    Slovenia, EU
    9
    Hi! I dont know how it goes on sumitomo, but at krauss maffei we have to optimise heaters. Machine does that by herself, you just have to run this optimisation and then she measure power and resistance, comsumption,... And then its fine. I think that you have something similar.
    103
    We had someone wire all the heater bands together on a Sumitomo and so it overheated one of the heater bands when the other two heater bands died.
