Thread: Calculation Method for Clamping Force needed
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Dec 2018
    Question Calculation Method for Clamping Force needed
    I need to understand the calculation method for the clamping force needed depending on the part dimensions, cavity, and machine pressure injection.
    Here is what I have:
    1.- See the part dimensions attached.
    note: dimensions in inches
    Part weight: 46 grs.
    2.- The number of cavities is 4
    3.- The machine pressure injection is 213 Mpa.
    4.- The part material is Nylon 6/6
    Is this data enough to calculate the CF?
    Jun 2017
    Ningbo zhejiang Province China PR
    10
    Re: Calculation Method for Clamping Force needed
    I am trying to enclosed a picture, but I do not have the access. Sorry. clamping load =specific. clamping force* project all areas( all parts and runner).
    200
    I'll generally use 3 - 5 tons per square inch of molded plastic at parting line
    Slightly higher if slides are used
    Ultimately the molded part itself will tell you where tonnage should be - ie run a little faster injection speed/holding pressure as a 'worst case scenario' and just keep coming down on tonnage until you start to see little flash in areas
