10th October 2022, 02:50 PM
insulation material
Hello all , There is a metal (alloy) mounted on the plastic (PA6,6 30% GF). I am looking for an insulation material that I can use between metal and plastic. Current will flow through the metal and heat the plastic. This material that I will use should insulate between metal and plastic and should not adversely affect the electric current. is there anyone who has experience with that ?
