23rd February 2012, 04:21 AM
Nautilus Software Question
When using your new Nautilus Software, and doing the viscosity curve portion of the 6 step validation process, what does one enter for intensification ratio if the press is electric? 0? 1?
Keep on molding!
23rd February 2012, 02:12 PM
We have a couple of niigata electrics and the pressures are already in plastic pressure. max 27,000 on one and 31,000 psi on the other. I suppose you could divide by 10 and put this number as the hydraulic pressure and then put an intesification ratio of 10
23rd February 2012, 03:43 PM
Brent, The intensification ratio for electrics would be 1. The formula is Viscosity = Pk Pressure X Fill Time X IR. So IR cannot be zero.
PJ, In the software you can put plastic pressure or Hyd. I have both options.
24th February 2012, 02:54 AM
Yup, the data at zero didn't look very logical at all!!!
Keep on Molding!
