14th September 2022, 10:34 AM
PVC Moisture content
Hi all, we are facing silver streaks issue in PVC molded fittings . we are doing the inhouse compounding and the compounded mix is pelletized and using for molding operation. we are predrying the pelletized material twice @80 degree celcius and the silver streaks issue is going. My question is it possible to accumulate moisture from the compounding operation. we are not storing material in warehouse , we are directly using it from pelletizer. Can anyone help.
15th September 2022, 05:37 PM
Re: PVC Moisture content
PVC isn't hygroscopic so I've never seen it dried. I would bet one of your additives is carrying the moisture or its shear or residence generated. For shear, I'd expect a narrow area or sharp corner in the tool is degrading the resin as you inject it. BTW-Do you run this in a cold runner?
26th September 2022, 11:41 AM
Maybe its the extensive drying you describe. Try to reduce it and check the result. ("Too much dry(ing) will kill you "
j
1st October 2022, 08:34 PM
Hi Rick , we are running cold runner,initial investigation found that the hot mixing breather was blocked and the pelletizing barrel vacuum was not enough .Thanks
1st October 2022, 08:37 PM
Single time drying unable to eliminate the silver streaks, whereas two times drying is eliminating the silver streaks effectively.still searching for the root cause.Thanks
6th October 2022, 10:49 AM
Ok, tell us more about the process and equipment.
temperatues (setup)
plastification setup
residence time
inj. unit and machine inlet and outlet diameters.
tool runner system
pictures of problem
