28th January 2022, 07:43 AM
Gloss level improvement for HDPE
Dear Members,
Our company want to produce one article "Watering Can" - the process will be made by the blow mold equipment, we have the HDPE (prime granules special for 10 L water can) + green masterbatch granules to make the green color.
The problem that we encounter is that the surface of the water can need to be shining (shining green) - what we will need to add for the HDPE to make the shining surface?
Thank you
28th January 2022, 08:30 AM
Re: Gloss level improvement for HDPE
I hope someone can answer your question here. We are all into Injection Molding primarily.
But with my experience in Injection Molding, I am not sure if you can get good gloss via blow molding. In injection, we use high pressures but those are probably not available in blow molding. I hope I am wrong. Please keep us informed.
All the best to you!
