Brown spot defect
Hi all,
This week we have an issue with Nylon6,6 GF30 injection a Brown spot appeared in the extremity of the part. First, we clean up the mold vents thinking that's a problem in gas evacuation but it didn't work secondly we verify the clamping force but it didn't work also.
Any suggestions would be appreciated.
Thanks.
Re: Brown spot defect
Pictures of the defect will definitely help.
1 Attachment(s)
Very difficult to see. But it appears as gas trapped or material degradation.
I'd recommend slowly the injection speed. If that doesn't work, perhaps lowering the barrel temps.
thank you, I take your advice into consideration and I will give you the feedback.
yes, I fix it. as you said I worked on the injection speed in the level of filling this area of the part and the results were Good.
Thank you very much for your support.
