EPDM material selection for injection molding
I have a military application that the spec calls out black EPDM that must be IAW SAE-AMS 3260. It is for molding a backshell from the connector to the wire bundle. I have a small 20T vertical press that I plan on using. Any help and/or direction to find where I can find pellet resin would be great!
thank you,
Paul
Re: EPDM material selection for injection molding
Contact Kraiburg, Santoprene, Washington Penn, and Softer that I deal with currently. There are several others but that's a start and they should know the spec you mentioned if they've done military work before.
